Page 1 of 2
Horn cast tap
Posted: Sun Feb 01, 2015 6:49 pm
by sydduckett
I need to tap the threads on a series 3 horn cast but I need a tap that pulls the swarf out. I'm told their are two types one for closed threads and one for open?
any kind soul point me in the right direction
Ta
Sef
Re: Horn cast tap
Posted: Sun Feb 01, 2015 7:23 pm
by monument7
Normal hand taps will do starter, second and plug or a single machine tap. Either way lubricate and clear tap and swarf out regularly
Re: Horn cast tap
Posted: Mon Feb 02, 2015 12:08 am
by YAMLAM
the tap you speak of is called a spiral flute, as opposed to a spiral point. try using that in a google search. if you get stuck PM me.
Re: Horn cast tap
Posted: Mon Feb 02, 2015 12:42 pm
by HxPaul
I thought all taps made for cutting a thread cleared the swarf,surely thats the point,they clean the thread as you cut.
Re: Horn cast tap
Posted: Mon Feb 02, 2015 12:59 pm
by monument7
Depends on the hole. If its a through hole then the swarf is forced through and out the bottom of the hole. If it's a blind hole the profile of the cutting edge makes the swarf come out the top of the hole to stop binding.
On hand tapped holes none of this is really relevant as you should clear the swarf as you go no matter which tap you use. Common sense really.
Re: Horn cast tap
Posted: Mon Feb 02, 2015 11:42 pm
by gp200ts1
or use tapsticks. they are a soft tallow stick that pops into the hole and as you tap the thread they get forced back out the hole taking the swarf with them
Re: Horn cast tap
Posted: Tue Feb 03, 2015 1:28 am
by monument7
I sent you a pm
Re: Horn cast tap
Posted: Wed Feb 04, 2015 11:09 pm
by sydduckett
Monument has come to the rescue, top man!
Re: Horn cast tap
Posted: Thu Feb 05, 2015 2:46 pm
by dirtyhandslopez
If you've a compressor handy, just blow it out as you're going along, saves buying a new tap.
Re: Horn cast tap
Posted: Thu Feb 05, 2015 2:52 pm
by ducksta
dirtyhandslopez wrote:If you've a compressor handy, just blow it out as you're going along, saves buying a new tap.
with your safety glasses on
