Jetting advice for reed valve 200
Posted: Wed Jan 28, 2015 1:13 pm
I have nearly finished the porting on my St4 200 Iron barrel that is to be fitted with an Atomic small reedvalve and 28mm PHBH with an Adj power jet and modified Mahle piston.
Previous to this the engine was run as a stock Indian barrel with Mahle piston and the 28mm (non PJ) jetted as follows - X13 needle (top clip), MJ 105, P 56, AV264, 300 Float valve and air bellows with foam filter, exhaust is a Taffy Copy.
I hope to have this finished and in the scooter this weekend and so far have upjetted the Mj to 120 in preparation for starting and running in (new rings fitted). Does this sound about right to start with or do I need a bigger MJ (power Jet is closed at Moment).
Any advice greater appreciated as nearest dyno is 25 miles away and i do want to get there!! Andy
