MMW rear disc brake on P2
Posted: Tue Jan 27, 2015 4:28 pm
I've fitted the main central holding bracket and removed material from the case so the disc carrier clears it.
I've also shimmed the caliper to be central to the disc.
However I have then tried to fit an sip tubeless rim and it rubs against the caliper.
I used washers behind the rim to push away and it needs 5.5 mm to give clearance.
Question is , will 5.5 mm from the normal position on the hub cause me drive or handling problems?
