Flywheel
Posted: Wed Jan 21, 2015 8:24 am
by ArmandTanzarian
My Rally engine (non-Femsa) has the old original Ducati flywheel that I assume has been on there since new. Even with a new stator and CDI the spark is a bit wishy-washy.
Has anyone tried the SIP lightened flywheel. Apart from (hopefully) improving the spark, at 1.7Kg, it weighs a bit less than standard too.
http://www.sip-scootershop.com/en/produ ... +_51001000
Re: Flywheel
Posted: Wed Jan 21, 2015 10:36 am
by Ginch
I've had one on for a couple of years. It's fine but I can't really make a comparison as it's been so long.
Have you looked at getting your flywheel re-magnetised? If that's not the issue you've done your money but woth investigating.
Re: Flywheel
Posted: Wed Jan 21, 2015 2:03 pm
by ArmandTanzarian
Ginch wrote:I've had one on for a couple of years. It's fine but I can't really make a comparison as it's been so long.
Do you know anywhere in the south east that does remagnetising?
Re: Flywheel
Posted: Thu Jan 22, 2015 9:54 am
by Ginch
No I don't but it's worth chasing up, these guys do it for a tenner.
http://www.scootopia.co.uk/page/97/Our-Services
Re: Flywheel
Posted: Thu Jan 22, 2015 11:36 am
by goldeneye
that SIP flywheel looks a bit expensive like! see if you can get a px disc leccy start flywheel, take the ring gear off, and send it to Beedspeed to lighten, the last one they did for me cost about a tenner +postage. you should be able to pick a flywheel up cheap enough.
Re: Flywheel
Posted: Thu Jan 22, 2015 11:58 am
by GLscoot
It may be worth buying one of the vintage motorcycle magazines, as there should be someone close by who will do it. Was there not an article in Scootering a few years back on this subject.
http://www.afrayspeed.co.uk/index.php?p ... buteID=ELE
Re: Flywheel
Posted: Fri Jan 23, 2015 9:05 am
by Ginch
Re: Flywheel
Posted: Fri Jan 23, 2015 9:18 am
by Jxmiddle
For the remagnetising it's worth called Slip stream (motorcycle tuners) in Sevenoaks. I don't think they will do it but they would likely know someone who does, they seem to have a wide circle of expert services they know of.
John
