Page 1 of 2
Tuned engine maintenance
Posted: Sat Jan 17, 2015 10:58 pm
by alanscottj
Now that I have spent a fortune on my engine and finally got it running spot on, dyno'd and have ironed out all the running in problems (thanks to this forum!) I intend to keep it well maintained and serviced. What do you guys do on a regular basis to keep your tuned engines in good running order?
Many thanks in advance
Scott
Re: Tuned engine maintenance
Posted: Sat Jan 17, 2015 11:04 pm
by Norrie Bodge
Thrash-it
Main one I thinks is clean carb every 1000miles or so
Gearbox Oil changes when needed.
& then thrash it again
lol
Posted: Sun Jan 18, 2015 1:59 am
by coaster
It's fair to assume that a tuned scoot will see some harder riding so frequent checks on the tightness of vital nuts and bolts such as wheel and hob nuts, cowling screws. Check spark plug. If you do any sustained high speed runs on dial carriageways then pay extra attention to tyre pressures. I'm sue there will be more suggestions
Posted: Sun Jan 18, 2015 8:41 am
by warts
Stuff like rings will wear out much quicker.
Carb settings, timing and plugs will be more critical.
Mistakes could be fatal.
Posted: Sun Jan 18, 2015 9:59 am
by shocky
Clutch and chain take a hammering as do sprockets , things like a ring change will r3quire not just rings but gaskets as well I usedto check mine every 3000 miles on a ts1 the side case would come of as well adjust chain check for rocking on rear sprocket endplate nuts etc maybe buy a few side case gaskets from te same source as they can vary in thickness and quality , also think of ways to make things easier to remove to make it seem less like a chore I aslo change all my inner cables every few years depending on how many miles ive done it might seem a waste of money but ive never had a cable snap in the last 12 yrs or so
Posted: Sun Jan 18, 2015 3:50 pm
by 22/2
warts wrote:Stuff like rings will wear out much quicker.
A bit extreme, don't you think?
Posted: Sun Jan 18, 2015 5:10 pm
by ducksta
listen to it if it sounds ok leave it, just set a date for a service/tinker and enjoy riding it till then.
Posted: Sun Jan 18, 2015 5:38 pm
by warts
22/2 wrote:warts wrote:Stuff like rings will wear out much quicker.
To your engine.
Posted: Sun Jan 18, 2015 6:49 pm
by rosscla
And if you don't check your brakes...
Posted: Sun Jan 18, 2015 8:54 pm
by 22/2
warts wrote:22/2 wrote:warts wrote:Stuff like rings will wear out much quicker.
To your engine.
Ahhhhh I see.
