TV Crank Build
Posted: Sat Jan 17, 2015 1:59 am
by Lamaddict
Can you use a normal 58 Li/SX crank and just swap out the conrod for a TV one? I'm getting a TV rod from Indian. It's only for a standard TV set up.
Re: TV Crank Build
Posted: Sat Jan 17, 2015 3:28 am
by Grumpy225
Yes, they have the same flywheel taper (if that's what you are asking). Assuming of course the big end is the same between the rods.
They both are 58mm stroke only the rod length and piston are different.
Re: TV Crank Build
Posted: Fri Jan 23, 2015 11:25 pm
by corrado
It'll depend on the crank pin size I guess, I think older ones were a different size to later GP ones. Anything from India might be GP sized. That info was on the old tech site that MB had but I couldn't find it on MB's site. Maybe someone here has a link.
