Crank confusion
Posted: Thu Jan 15, 2015 10:16 pm
by jedan71
Hi, daft question time as I have just purchased a new crank, from some one local. It is brand new in box, never used.
My question is, what's the difference between Mec Eur & Mazzucchelli cranks, or are they the same thing?
I have seen the recent comments that Mec ones have had recent issues.
I purchased the Mazzucchelli GP 58/107 one...
Are they any good? As the prices shown on the internet can vary from £379 -£190.
Alex
Re: Crank confusion
Posted: Thu Jan 15, 2015 10:26 pm
by shocky
Re: Crank confusion
Posted: Fri Jan 16, 2015 3:00 am
by jedan71
Even more for the confusion,
PmTuning say "The best crank to buy for your lambretta GP 200cc when working to a budget or using mildly tuned cylinders" Yet SIP say "The perfect crankshaft for TS 1 engines, a solid cone and high quality bearings provide maximum durability of the engine."
Seems a big jump from mildly tuned budget machines to TS1 engines, I am ok fro the moment as i am looking at SR175 barrel but could this be used with mugello or imola or even RB?
Re: Crank confusion
Posted: Fri Jan 16, 2015 3:16 am
by corrado
Also says .......
This Mazzucchelli Crankshaft for Lambretta GP200 comes with high load silver cage big end bearing, full circle webs to boost primary crankcase compression
............. but it hasn't got full circle webs. WTF........
Generally thought of as a none race GP200 crank. Equally confusing is for years MEC have been promoting 2 different GP cranks as "race" with lots of thought that one of them isn't. I doubt if you'd find one of those cranks in any Race engine. You probably won't find many 107 conrods in Race engines either.
Marketing men won't rebuild your engine when their so called race crank breaks.
Re: Crank confusion
Posted: Fri Jan 16, 2015 10:07 am
by shocky
corrado wrote:Also says .......
I had a race crank from PM and it wasnt even shimmed I had a ported muggelo at the time and didnt risk it so it went back I then got a crank from AF which twisted aft3t about 6 months of low usage maybe 1000 miles I had it straightend and I tig welded it and never looked back I was told the AF cranks only neec 7 tons to press the pin out and indian ones need 10 so I went with and indian this time
Re: Crank confusion
Posted: Fri Jan 16, 2015 10:25 pm
by Muppet
injun 10 ton to press? 4 ton closer to truth; a 10 ton press doin it
Re: Crank confusion
Posted: Fri Jan 16, 2015 11:35 pm
by shocky
Muppet wrote:injun 10 ton to press? 4 ton closer to truth; a 10 ton press doin it
I ztand corrected never having done it myself 8-)
Re: Crank confusion
Posted: Mon Jan 19, 2015 8:44 am
by jedan71
So other than some poetic licence, they are not race standard but either model is capable is being used in mid tune or even use on the higher grade tunes like TS1 etc?
