Rear hub seal
stonerosesmod
Main scooter: Lambretta Li150S
Any tips on what to use on a PX200 EFL rear hub seal on install? Do you heat casings slightly first or should it just tap down with a socket?
gaz_powell
It should go relatively easily - make sure the the casing is spotless and a thin spray of silicon grease and press home by hand or a little help with a drift if necessary i turned a hardwood solid round drift for the internal type.
stonerosesmod
Cheers Gaz,will give it a go.
