Weld toolbox door
vicvega
Main scooter: Scomadi
what's the best way to fill the toolbox door hole, weld in the old door & fill or cut a piece to fit. & can you weld in a stainless door? Cheers
Hi Vic, I filled the toolbox door hole on a GP. The best way I found was to use the original door but tap out the lip on the door flat. This in turn fits the hole in the frame very well. Then I welded it from the back and a few tacks of weld on the front. A little filler in the gap and the job was done.
vicvega
Nice 1, didn't think about straightening the edges. I'm glad I asked instead of going blundering in. Makes a change!
Thanks
essexgp
Same here, used an old scrap toolbox door and got it welded in from behind and tacked from the front
Bit of filler and jobs a good un :D :D :D
    Users browsing this forum: Baidu [Spider] and 2 guests
