ts 185 conversion
Posted: Fri Jan 02, 2015 9:45 pm
by dave wheeler
ok out of decent pistons for my tv175 so am thinking of using a suzuki ts185 piston, i believe all i need do is use a 2mm packing plate but does the head need reprofiling and if so who does this, a rough cost and what should the piston to bore clearance be?
Re: ts 185 conversion
Posted: Fri Jan 02, 2015 9:59 pm
by mawso
http://www.scooterrestorations.com/lamb ... -assembly/
A few SR 175 pistons here which might save you a rebore, don't know what size you're on now but some oversizes still available. Think you may need a packer still as they're not same as TV pistons, But they are wire rings and reasonably priced.
Failing that Grampian motors in Liverpool for a Mitaka TS185 piston, they are the official Mitaka agents I think.
Posted: Sat Jan 03, 2015 12:18 pm
by camel
I've not long done one..I used a 25 quid khc piston off eBay.I gave it 0.003 thou clearance and used a 2mm packer that's with the TV rod.the head will need a reprofile to suit the flatter piston crown,I did my own so not sure on cost.
Posted: Tue Jan 06, 2015 2:23 pm
by Stokie
Pretty much any of the tuning guys can sort your head out. You could send it off to anyone I guess.
Harry Barlow (ProPorting) in Leicester did mine, can't remember the cost but was something like £20.
MB also do it - see the following link - http://www.lambrettaspares.com/spares/c ... ab016.html
Posted: Wed Jan 14, 2015 7:58 pm
by grimspeed
Yamaha CT1 175 Same compression hight !
Posted: Wed Jan 14, 2015 9:47 pm
by Muppet
grimspeed wrote:Yamaha CT1 175 Same compression hight !
66mm bore ?
Posted: Thu Jan 15, 2015 3:02 pm
by rosscla
Posted: Fri Jan 16, 2015 9:24 am
by ForemanBob
dave wheeler wrote:ok out of decent pistons for my tv175 so am thinking of using a suzuki ts185 piston, i believe all i need do is use a 2mm packing plate but does the head need reprofiling and if so who does this, a rough cost and what should the piston to bore clearance be?
I'm currently selling a Mitaka one on ebay... currently at a very modest 99p... ;)
http://www.ebay.co.uk/itm/291352069384? ... 1555.l2649
Posted: Sun Apr 03, 2016 6:56 pm
by grimspeed
Could try a Suzuki EP 175 ! Same as a TS 185 "32mm compression hight " But starts at 62mm !
