Monza 240 changing from 1 ring to 2 ring piston?
Posted: Thu Jan 01, 2015 5:23 pm
by justbretta
New year and starting it off with a silly question. I currently run a tuned Monza 240 and it was built with a Husqvana one ring piston, but I'm looking to change it to a two ring piston for longevity. The question I have is can I simply just change the piston for a two ring equivalent or is there more to it than that, ie will anything else need changing like the head re-profiling due to an increase in compression? Carb rejetting etc? Any advice would be much appreciated.
Re: Monza 240 changing from 1 ring to 2 ring piston?
Posted: Thu Jan 01, 2015 8:48 pm
by ricalnic
My first thoughts would be, ring peg position, to ensure the ring ends do not catch any of your ports. And it may be a like for like Husky piston but has it received additional work like cutaways etc
Posted: Thu Jan 01, 2015 9:25 pm
by rosscla
You should not need to reprofile the head unless the new piston has a different dome height. I'd have thought it unlikely you'd need to rejet.
Mark the ring positions in the crown to check they don't run through the ports.
Posted: Fri Jan 02, 2015 8:39 pm
by tavspeed
what size is the husky piston,and what size is the little end,where did you get it from.cheers
