Page 1 of 2
egt probe position
Posted: Thu Jan 01, 2015 3:02 pm
by tea5ive
where does the probe need to go on the exhaust for an egt gauge. cheers simon
Re: egt probe position
Posted: Thu Jan 01, 2015 4:55 pm
by lockman69
100mm down from the piston skirt...
Posted: Thu Jan 01, 2015 5:33 pm
by tea5ive
lockman69 wrote:100mm down from the piston skirt...
is that at tdc or bdc ? cheers simon
Posted: Thu Jan 01, 2015 5:35 pm
by coaster
+1 but try to position it so that the probe faces the rear just to protect it a bit. Difficult to achieve though due to the position of the bend.
Posted: Thu Jan 01, 2015 9:02 pm
by tea5ive
its going on a b-race, there is a fair bit of room so will be able to tuck it out of the way. so is the measurement taken from tdc or bdc ?.cheers simon
Posted: Thu Jan 01, 2015 9:20 pm
by rosscla
It's from the side of the piston, so TDC or BDC doesn't matter
Posted: Thu Jan 01, 2015 11:38 pm
by tea5ive
rosscla wrote:It's from the side of the piston, so TDC or BDC doesn't matter
cheers for the info. still need a datum point to measure from don't I.... ? lets say exhaust port centre ?. don't want to feck it up . cheers simon
Posted: Fri Jan 02, 2015 12:18 am
by Muppet
from the piston in the open port
muppet,
Posted: Fri Jan 02, 2015 11:37 am
by slangen
It does not have to be exactly 100mm, measure from piston to exhaust gasket face on cylinder then from exhaust gasket face on stub or exhaust, add thickness of gasket and mark the u bend. You create your own reference of the reads you get, if you get an air leak or so, you will notice a raise in temp. From your own reference when everything was fine...
Posted: Fri Jan 02, 2015 1:20 pm
by tea5ive
thanks for the info, I no what I am doing now 8-) . will have a measure up and weld the stub on for the probe. will take a pic or two of the progress. cheers simon
