Spanish Jet regulator bracket?!?
Posted: Mon Dec 29, 2014 11:42 pm
by purple_pill67
Does anyone do a bracket for a regulator/cdi/wassell for a Jet 200?
Seems to only have the 2 holes on the flywheel side and not be the same as an Italian fixing.
Ideally wanting to tidy my electrics up and fit an under panel carrier for oil but wont be able to unless i can move the cdi/wassell out the way.
Re: Spanish Jet regulator bracket?!?
Posted: Tue Dec 30, 2014 9:38 am
by Monty
Plenty of flat sides and bottom to your proposed box that can be used to bolt stuff onto
Posted: Tue Dec 30, 2014 3:08 pm
by theageofindustry
You could drill the rear support for a standard Italian cdi mount.
That's the easiest solution and what I did on mine.
Posted: Tue Dec 30, 2014 5:18 pm
by purple_pill67
Ok, i havent got an oil box yet til i know what i can do with the bits.
Didnt really want to drill the frame
