Lambretta choke lever fitted to Vespa
Posted: Mon Dec 15, 2014 7:14 pm
by Blakey43
Hi all, I'm going to use a 28mm dellorto and 90 degree cable elbow with a Lambretta choke lever mounted in just about the standard Vespa choke lever location. The trouble is the cable outer is spot on for length but the cable inner is too short. Does anyone know where I could get hold of a longer cable ready made up?
Thanks
Re: Lambretta choke lever fitted to Vespa
Posted: Mon Dec 15, 2014 7:47 pm
by jason frost
Have you got the right cable to go with the elbow ?
Posted: Mon Dec 15, 2014 8:33 pm
by Blakey43
No just the standard cable with small barrel at one end and a nipple at the carb choke end.
Posted: Mon Dec 15, 2014 10:12 pm
by jason frost
You need the Li one with the longer inner
Posted: Mon Dec 15, 2014 10:31 pm
by Blakey43
Cheers, I'll have a look.
Posted: Mon Dec 15, 2014 11:55 pm
by Knowledge
I make custom choke cables for Lambrettas. If you let me know how long the outer should be, I'll make you a cable.
You can have the outer in red, black, grey or silver braid.
£5 delivered.
Posted: Tue Dec 16, 2014 12:53 pm
by GLscoot
Whats the chance of some images of this set up.
cheers Gary
Posted: Mon Dec 22, 2014 1:41 pm
by Blakey43
Thanks knowledge but I'm sorted now. I'll bear you in mind though, I'm bound to snap it.
No problem with photos, I'll post some when I get it fitted.
Regards~
Posted: Sun Jan 04, 2015 6:13 pm
by Blakey43
Knowledge wrote:I make custom choke cables for Lambrettas. If you let me know how long the outer should be, I'll make you a cable.
£5 delivered.
Hi Knowledge, as predicted in a recent post I've wrecked my choke cable trying to adapt it for a 28mm dellorto with a 90 degree elbow and a Lambretta choke lever I'm fitting it to a Vespa frame.
Would it be possible to make me 2 with the outers being 300mm long and black?
Posted: Mon Jan 05, 2015 5:47 pm
by Eibar
