Page 1 of 6
Our latest spec reed-valve crankshaft - (Malossi 221cc)
Posted: Mon Dec 15, 2014 2:51 pm
by drunkmunkey6969
Re: Our latest spec reed-valve crankshaft - (Malossi 221cc)
Posted: Mon Dec 15, 2014 5:12 pm
by OzOAP
Nice work. Im planning on doing a reed Polini so be interested to see if ur pleased with the new crank mods.
Posted: Mon Dec 15, 2014 5:21 pm
by sean brady scooters
we actually have used one of these cranks on a reed valved std polini with an old pm pipe ,it still made 22bhp and 19ft/lbs at only 6,500 revs over a 3500 usable rpm range. A better and more suitable pipe would give even better results .
Posted: Mon Dec 15, 2014 6:45 pm
by ducksta
proper tuning, taking a piece of kit then taking it to another dimension well done.
Posted: Mon Dec 15, 2014 10:48 pm
by cartmel808
Seen this crank in the flesh last week whilst visiting the garage & it's a piece of art!
Lovely work Sean...
Posted: Tue Dec 16, 2014 5:24 pm
by drunkmunkey6969
Posted: Tue Dec 16, 2014 11:15 pm
by Muttley McLadd
Out of interest.. what's the advantage to a lighter crank?
Posted: Tue Dec 16, 2014 11:37 pm
by drunkmunkey6969
Muttley McLadd wrote:Out of interest.. what's the advantage to a lighter crank?
It weighs less. Heavier ones weigh more. I can carry at least 3 light ones, but only 2 heavy ones.
That's the main advantage.
Posted: Wed Dec 17, 2014 12:23 am
by shamrockexpress
Everybody is making bigger cranks and bigger casings to house the bigger cranks like Jap style cranks with fat webs with more surface area on the pinsto stop twisting..........................
So good luck Dan if you can make them smaller and work all the same CERTAINLY REVOLUTIONARY.
Posted: Wed Dec 17, 2014 12:57 am
by drunkmunkey6969
shamrockexpress wrote:Everybody is making bigger cranks and bigger casings to house the bigger cranks like Jap style cranks with fat webs with more surface area on the pinsto stop twisting..........................
What you are talking about is an entire new design of high-end and very expensive casing, to house bigger cranks. Like the BSG 305cc engines etc. These are usually small production run or bespoke billet casings. This is incomparable to what we are doing......? We are simply reworking existing cranks, on factory casings, as it suits the budget of 99% of our customers. In addition.......of all the metal removed, nothing we do reduces the amount of metal around the interference fit of the pin. So twisting isn't a problem. And in any case....we rarely see Vespa cranks twist, unlike Lambretta. You have to compare like for like when talking about cranks and casings, and unlike Lambretta, the PX reedvalve blows directly onto one main web......which Sean has therefore flowed heavily. We have very good results with these cranks.
I can however see the benefit of thicker webs and bigger crank casings on Lambretta.....but that's a different story.
