25mm Dellorto Float melt
Mr G in NYC
Main scooter: SX200
So yesterday had a quick errand to run and figured I'd use my trusty
old Silver special casa kitted 185 Dellorto 25mm. Kicked it in life...
died straight away....? Kicked again died.... wouldn't hold a tick over,
figured it was a blocked pilot jet or fuel tap issue ....took carb off and
viola .....carb float full of gas :( this is a new carb about 500 miles on
this set up ............Also had it happen to a kitted SX200 with a 30mm
dellorto........? Anyone else having these problems with these floats ??
If so how are you sealing them ? what glue to prevent the ethanol melting
the existing factory glue ? I need to pull all my new carbs and glue them .
Any insights would be most welcome ....... 8-) G.
Mr G in NYC
Main scooter: SX200
Not only but also ......BGM CDI failure as well :? G.
Angry Bloke
Yes I've had the same on a couple of PHBH floats - I now carry a spare :roll:
Strummer10
Yes, i had a 30mm Delorto on my Avanti kit and have to date (in 2 .5 years) got through 3 new floats because of the same problem. Thing is on the Isle of Wight in August i climbed a steep road and the bike was flooding and trying to cut out, so i believe the float may have melted again. Not sure what the answer is, as it seems to keep doing this. I have an old 80s float from a 30mm carb used back then so may try this....
I had to sort out a mate's TS1 that suffered the same on a new white float PHBH 30mm :(
belly
Main scooter: series 2 Li with TS1
you can get the black solid float for the PHBH this should solve your problems with ethanol
Strummer10
thanks, i'll source one and try that
    Users browsing this forum: Google [Bot] and 12 guests
