YZ250 piston
Posted: Wed Dec 03, 2014 10:39 pm
by carlos fandango
Im looking for an oversize 71mm piston for my cast linered RB .
Could someone tell me the gudgeon pin diameter of the yz piston ,and a conrod thats suitable to use.
Thanks
Russ
Re: YZ250 piston
Posted: Thu Dec 04, 2014 5:32 pm
by hobospeed
http://www.wossnerpistons.com/products/ ... okietest=1
Looks like the pin is 18mm and the compression height is 33mm so you'll need a longer rod with the large small end diameter.
Tim
Re: YZ250 piston
Posted: Thu Dec 04, 2014 10:01 pm
by Rich_T
For the rod I would use a yamaha outboard rod 6H4 which is 116 long , 22mm crank pin and 18mm gudgeon pin.
The other option for your piston is a DT250 which is cheap and has oversizes to 71mm. Both the DT250 and YZ250's have 18mm gudgeon pins
Re: YZ250 piston
Posted: Sat Dec 06, 2014 12:07 am
by carlos fandango
Thanks for the replies ....ive decided to go with a wossner 72mm from AF , as the other options meant changing conrod and head
Re: YZ250 piston
Posted: Fri Dec 12, 2014 11:49 pm
by corrado
carlos fandango wrote:Thanks for the replies ....ive decided to go with a wossner 72mm from AF , as the other options meant changing conrod and head
I take it they've got 16mm pins?
