Vespa PX 221 help
Posted: Tue Dec 02, 2014 3:13 pm
Hi everyone i need help with tuning my engine iv got a few problems. I have a malossi 210 mazzuchelli 60mm crank with 1,5mm head distancer, phbh 30mm carb with polini manifold and ramair filter, malossi 4-plate set with xxl springs and thw clutch has a ring welded, polini rh exhaust, lml 2200g flywheel, DRT 24 teeth on clutch.
The problem is that it wont idle even with the idle screw all the way in it goes great at higher revs but i am not pushing it until i run the engine in. The ignition is set at 17 degreas BTDC. Other than the idle problem is that it starts a bit harder aswell before i did the rebuild a few weeks ago it would start at first kick cold or warm with or without the choke, but know it is hard. Tried various main jets, with and without air filter, the needle on al the slots but still the same even screwing the air mixture doesn't help. I tried to put the standard carb back just with bigger jets and it was the same thing. Also when i give full throttle it starts to bog and turns it self of. Hope its nothing seriuos since i have just finished rebuilding the engine. Please help with some ideas and advice. Thanks in advance !!
