Flywheel thread
Posted: Wed Nov 19, 2014 11:46 pm
by Blackhawk
I'm currently restoring a Moto Vespa 150s and the flywheel thread is stripped so a puller won't get it off. Two things: How can I get the flywheel off and can the thread be repaired or re tapped to the size of a PX flywheel puller. I thing the thread is 22mm and a PX puller is 26mm.
cheers
Re: Flywheel thread
Posted: Thu Nov 20, 2014 11:57 am
by GLscoot
I find hard to believe the thread on the flywheel has stripped. You can buy a flywheel puller for all vespa flywheels, try beedspeed and allstyles. I know I have two flywheel pullers, will check the size. You could use one of those claw pullers, the have three legs and a central threaded bolt (forget the name)
As for replacing the boss, will a PX one fit the crank, I would get it repaired.
Re: Flywheel thread
Posted: Thu Nov 20, 2014 12:20 pm
by Blackhawk
The puller is from beedspeed I'm taking the engine over to buzz solo motor tomorrow worst case is a new flywheel for 50 quid hopefully sorted with the correct puller. Mate reckons a pk my fit over the crank so that's option 2.
Re: Flywheel thread
Posted: Thu Nov 20, 2014 1:41 pm
by hendy
GLscoot wrote:I find hard to believe the thread on the flywheel has stripped. You can buy a flywheel puller for all vespa flywheels, try beedspeed and allstyles. I know I have two flywheel pullers, will check the size. You could use one of those claw pullers, the have three legs and a central threaded bolt (forget the name)
in general i'd avoid 3 legged pullers, they often cause damage where the legs 'grip' whatever it is you're pulling off (
), especially if it's soft stuff like aluminium.
however, if you have no choice, then I guess you have no choice, but i'd explore other avenues first.
