Page 1 of 3
Points Timing
Posted: Sat Nov 15, 2014 8:09 pm
by philz
I am getting conflicting info for standard Li150 points. I am advised 21-19-17 degrees. Any advice welcomed. Thanks.
Re: Points Timing
Posted: Sun Nov 16, 2014 12:18 am
by jason frost
17deg
Re: Points Timing
Posted: Sun Nov 16, 2014 12:30 am
by Yanker
19deg (23 officially)
Re: Points Timing
Posted: Sun Nov 16, 2014 12:41 am
by bristolmod
Yanker wrote:19deg (23 officially)
+1 wot the geezer said
Re: Points Timing
Posted: Sun Nov 16, 2014 8:25 am
by philz
See what I mean! 17deg 19deg what would be the difference?
Re: Points Timing
Posted: Sun Nov 16, 2014 9:12 am
by drunkmunkey6969
philz wrote:See what I mean! 17deg 19deg what would be the difference?
2 degrees
Re: Points Timing
Posted: Sun Nov 16, 2014 9:49 am
by gerryjunior
i have my series 2 running on points, its a bog standard 150 ,i have it timed to 19 and it hasn't missed a beat in 3 years..but im no expert.
Re: Points Timing
Posted: Sun Nov 16, 2014 10:04 am
by Chris in Margate
Time it at 19 BTDC and only ever use the very best petrol you can buy.
Re: Points Timing
Posted: Sun Nov 16, 2014 12:23 pm
by Muppet
what is hapenin wen y retard it and why? yep it fires later but what hapens
Re: Points Timing
Posted: Sun Nov 16, 2014 12:29 pm
by bristolmod
the "burn" is not instantaneous- it tales time to completely combust. By timing "early" at say 19 BTDC, it allows the piston to travel to the very top of its stroke before all the mixture has burnt and produced the max amount of power. If its timed too "early", at say 21 BTDC, the piston on its upwrads stroke is fighting against the "explosion" which means lost power and more heat. If its too late, then the piston is already on its way down, which again means less power, but also it runs slightly cooler.
Its a balance really.
Back in the day, the fuel was "better" than the crap about today, which meant that timing was "better " at 21 BTDC.
