Tall 5 plate clutch center spider
Posted: Sat Nov 15, 2014 5:51 pm
by shocky
http://beedspeed.com/lambretta-clutch-c ... -8172.html
How much taller are they and dont they lift the driven plate out of the sprocket ?
Also wont they make the driven plate touch the kickstart ?
Re: Tall 5 plate clutch center spider
Posted: Sat Nov 15, 2014 6:42 pm
by 10 inch Terror
shocky wrote:Also wont they make the driven plate touch the kickstart ?
Yes they do. I purchased one ages ago and ended up binning it. It's hard enough fitting a standard clutch in without it rubbing, let alone an extended one. If you want to go down the 5 plate route, get the Readspeed 5 plate kit. I've got one in my 20 bhp Imola and its spot on. At under £50 they are brilliant value for money.
Posted: Sat Nov 15, 2014 7:23 pm
by shocky
10 inch Terror wrote:shocky wrote:Also wont they make the driven plate touch the kickstart ?
Yes ive seen them for £38
So whats the point I them
Posted: Sat Nov 15, 2014 7:43 pm
by 10 inch Terror
If I'm to be honest, I'm not sure. They may work with an extra thick side case gasket, as supplied by Cam Lam, but other than that, I'm stumped.....
Posted: Sun Nov 16, 2014 5:31 pm
by shocky
Do you still have it ill pay postage
Posted: Mon Nov 17, 2014 11:15 am
by 10 inch Terror
It's living happily inside my Imola motor....
Posted: Mon Nov 17, 2014 11:18 am
by 10 inch Terror
Unless you mean the spider? That's currently located 20ft under my local land fill site.
