Master cylinder
What sorts of master cylinder fit on this ?Image
Has it been modified from the scoot rs type
I don't know, I bought it from a for sale ad on here a while back, can't remember who from though...I have the name from paypal but that doesn't link back to who it was ...
Stampede
Main scooter: SX200
The ScootRS / Nissin master cylinder fits.
jason frost
Any in line set up will fit, you just need to cut it like they do with the ScootRS ones
The scoots rs one is too big IMHO, was thinking about trying to find something smaller .
Jason, I wondered about that as most of the bike ones seem to be 180 degree fitting. When cut are they only attached by the top fixing?
jason frost
Its has a fitting from the bottom as well, when you cut it to fit it just needs drilling and tapping for the new fitting.
Ok got it, cheers.
I always use ajp ones from a runner, dragster or speed flight you have to take a but of the throttle housing and a bit ofthe master cylinder takes a bit of time but a nice fix
rosscla wrote:What sorts of master cylinder fit on this ?Image
Could do with seeing it from the other side. For the last couple of years scootrs have been countersinking the hole for the top fixing and using a countersunk allen bolt. They must be cut on a template as they're easily interchangable from one scootrs master cylinder mount to another which is not the case with Sterling [SPAQ] or Saigon ones. You can buy the master cylinder already cut to suit.
