Page 1 of 2
Master cylinder
Posted: Sat Nov 15, 2014 4:48 pm
by rosscla
What sorts of master cylinder fit on this ?Image
Re: Master cylinder
Posted: Sat Nov 15, 2014 5:42 pm
by shocky
Has it been modified from the scoot rs type
Re: Master cylinder
Posted: Sat Nov 15, 2014 7:17 pm
by rosscla
I don't know, I bought it from a for sale ad on here a while back, can't remember who from though...I have the name from paypal but that doesn't link back to who it was ...
Re: Master cylinder
Posted: Sat Nov 15, 2014 8:36 pm
by Stampede
The ScootRS / Nissin master cylinder fits.
Re: Master cylinder
Posted: Sat Nov 15, 2014 10:04 pm
by jason frost
Any in line set up will fit, you just need to cut it like they do with the ScootRS ones
Re: Master cylinder
Posted: Sat Nov 15, 2014 10:38 pm
by rosscla
The scoots rs one is too big IMHO, was thinking about trying to find something smaller .
Jason, I wondered about that as most of the bike ones seem to be 180 degree fitting. When cut are they only attached by the top fixing?
Re: Master cylinder
Posted: Sat Nov 15, 2014 10:58 pm
by jason frost
Its has a fitting from the bottom as well, when you cut it to fit it just needs drilling and tapping for the new fitting.
Re: Master cylinder
Posted: Sat Nov 15, 2014 11:25 pm
by rosscla
Ok got it, cheers.
Re: Master cylinder
Posted: Sun Nov 16, 2014 5:35 pm
by shocky
I always use ajp ones from a runner, dragster or speed flight you have to take a but of the throttle housing and a bit ofthe master cylinder takes a bit of time but a nice fix
Re: Master cylinder
Posted: Sun Nov 16, 2014 8:31 pm
by corrado
rosscla wrote:What sorts of master cylinder fit on this ?Image
Could do with seeing it from the other side. For the last couple of years scootrs have been countersinking the hole for the top fixing and using a countersunk allen bolt. They must be cut on a template as they're easily interchangable from one scootrs master cylinder mount to another which is not the case with Sterling [SPAQ] or Saigon ones. You can buy the master cylinder already cut to suit.
