Stroking standard engine
Posted: Sat Jun 06, 2009 12:21 pm
I'm installing electronic ignition system (probably BGM stator & Indian flywheel) to my SX 200. I'm under the impression that it's wise to swap the crank to GP/DL type at the same time and as the long stroke (60 mm) ones are about the same price as normal ones I'm thinking about getting one too to gain some more cc's. What kind of options of different head/foot gaskets/spacers I have and how will they affect to the engine characteristics? I have standard cylinder & head (which I'm not willing to modify), AF Clubman and 22 mm Dell'Orto carb.
Right now I'm using standard 3-ring piston but if someone haves positive experiences with cheap Mahle pistons from SR I might get one to have it around if the inlet timing needs adjustments.
