Glaze Busting
Posted: Mon Nov 10, 2014 3:38 pm
Fitting my Li 150 with new piston rings. Can I wet n dry the bore or will it need a full blown honing in a workshop?
Where have I heard this method beforeipman wrote:you could use a full sheet of wet and dry folded into a cylinder,,insert into barrel and inflate a water ballon inside and give it a good pumping with some lube
Are we talking about glaze busting here or something else??????shamrockexpress wrote:Where have I heard this method beforeipman wrote:you could use a full sheet of wet and dry folded into a cylinder,,insert into barrel and inflate a water ballon inside and give it a good pumping with some lube![]()
A nods as good as a wink....philz wrote:Are we talking about glaze busting here or something else??????shamrockexpress wrote:Where have I heard this method beforeipman wrote:you could use a full sheet of wet and dry folded into a cylinder,,insert into barrel and inflate a water ballon inside and give it a good pumping with some lube![]()
