Centre badge
Posted: Thu Nov 06, 2014 10:46 pm
by Blackhawk
Another quick question. What's the technique for fitting the centre badge on the horn cover on a 150s. There must be a technique but I don't have it
Re: Centre badge
Posted: Thu Nov 06, 2014 10:51 pm
by 10 inch Terror
You have the badge holder I take it? It bolts to the frame through the horncasting and the badge then clips into that.
Re: Centre badge
Posted: Thu Nov 06, 2014 10:57 pm
by 10 inch Terror
One of these bad boys.
Re: Centre badge
Posted: Thu Nov 06, 2014 11:47 pm
by Blackhawk
The horn casing has 4 slits and the badge has 4 tabs that go into the slits. I'm having trouble with the technique of marrying the two up without damaging the badge.
Re: Centre badge
Posted: Fri Nov 07, 2014 12:33 am
by 10 inch Terror
Forget everything I said. I thought you meant a Lambretta 150! Sorry it's my age...
Re: Centre badge
Posted: Fri Nov 07, 2014 7:52 am
by Blackhawk
I managed to get it in. I had to put a curve in the tabs as they were snagging the frame inside. Anyhoo, job done.
Re: Centre badge
Posted: Fri Nov 07, 2014 9:23 am
by barnsleybilly
Do you mean an Ulma Golfball embellisher on a series 2?
