Causes of white spark plug
Posted: Mon Nov 03, 2014 11:57 pm
Ok my scoot is a std Gp 150 with an AF Clubman small bore, jet ex carb with (if memory servers me right) +2 above std on the main jet
Its done about 8k miles since I built it without an issue but when I went to Cleethorpes this year After I got there I decided to check it over and noticed the plug was looking decidedly white. Can't say how long it's been running lean for as I've probably not checked the plug for a year or two (1or 2k miles). Shocking and lazy I know. Anyway I checked the air hose and filter and could not find any faults and as the scoot had got me to Cleethorpes from Manchester, drove it home as normal apart from adjusting the air mix as much as I could on the carb. Still ran it flat out but tried to make sure I was not sitting at a constant throttle position for long periods, which I probably was on the journey out.
When I originally built it I did proper plug chops and everything
so it was definitely ok once and nothing much has changed since. Where should I look next for possible causes?
