exhaust stud
Posted: Fri Jun 05, 2009 7:34 pm
:bouncing: is it best to use the long bolts on the mounting bracket on a taffy pipe to the crankcase, or fit longer studs? thanks :bouncyeng:
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
cheers wezly, never gave it a thought about removing crankcase sidewezly wrote:if you mean the rear mount id use the 3 bolts provided, studs are better but you would struggle to remove the side casing.
