Page 1 of 2
t5 engine
Posted: Wed Oct 29, 2014 8:04 pm
by stanspeed
built a new engine for me t5 with a 54mm stroke crank and reed valve with a malossi 172 kit and a mmw head what would be the best packer plate or and head gasget combination to use im asking this before i buy the packer or head gaskets.
Re: t5 engine
Posted: Sat Nov 01, 2014 12:22 am
by fastfrog
check first your timing and squish then order. several ways to get the right combination.
Re: t5 engine
Posted: Sat Nov 01, 2014 5:15 pm
by stanspeed
hi fast frog firstly can i say ive seen your work and its the great work that u do wish i could do half of what u do.right timing is set up at 14 degrees and put a standard malossi base gasket on and was lent a 1.5mm head gasket all bolted up and and me squish if im reading gauge right im getting 1.1mm had it running gose ok but ive been told to go for a 1mm base and 1mm head gasket but getting confused as there is like u said differant combinations to use,u seem to no more about set than me what would u suggest .many thanks stan.
Re: t5 engine
Posted: Mon Nov 03, 2014 8:50 pm
by fastfrog
I'm confused...
First 14° is a bit low. You should fit your stator timing at 16°.
Second: check your malossi base gasket thickness. It should be around 0,3-0,5mm... then things will be easier to match.
Re: t5 engine
Posted: Tue Nov 04, 2014 11:42 am
by soulboy
keep the timing stock someone on here told me to change it when i put a malossi on it and it cost me a piston
Re: t5 engine
Posted: Sun Jan 18, 2015 5:33 pm
by smoore-gt225
stanspeed wrote:built a new engine for me t5 with a 54mm stroke crank and reed valve with a malossi 172 kit and a mmw head what would be the best packer plate or and head gasget combination to use im asking this before i buy the packer or head gaskets.
Hi you've said you fitted a mmw head did you do away with the o'ring and fitted a normal head gaset
cheers steve
Re: t5 engine
Posted: Sun Jan 18, 2015 5:51 pm
by goldeneye
My Malossi 172 runs a MMW cylinder head with no gasket, just the "O" ring. I did drill one stud hole to use the T5 head dowell, as the MMW head isn't made to accommodate the head dowell. pricey at nearly £160 , but its been on five years and never even had a hint of pinking , piston crown looked perfect on last strip down. runs a JL pipe and 28mm delly .
Re: t5 engine
Posted: Sun Jan 18, 2015 10:30 pm
by lambro
soulboy wrote:keep the timing stock someone on here told me to change it when i put a malossi on it and it cost me a piston
I run all my tuned Vespa's at 16.
More than just timing that can hole a piston.
Re: t5 engine
Posted: Mon Jan 19, 2015 11:27 am
by Jack221
Sounds to me like Fastfrog was first talking about port timing. If you want it to go as fast as possible then a 1.5mm base gasket. For city riding a 0.5mm base gasket. Decide what kind of riding you want it for, then get the head sorted to give a squish of no more than 1.0mm.
Re: t5 engine
Posted: Mon Jan 19, 2015 11:32 am
by Jack221
lambro wrote:soulboy wrote:keep the timing stock someone on here told me to change it when i put a malossi on it and it cost me a piston
Proving the rule that advancing the timing will need bigger jetting!
