Page 1 of 2
Porting Vespa Engine casings
Posted: Wed Oct 22, 2014 3:06 am
by Richjak
Anyone know of a good website or any other source of information for the porting of a set of P200 engine casings to take a reed valve and a Malossi 210 kit ??
Maybe you have already done this and could provide some tips hints and pointers.
Cheers.
Re: Porting Vespa Engine casings
Posted: Wed Oct 22, 2014 6:18 am
by LI150
Porting the casing is fairly straight forward just match everything. Eg barrel to casing and reed block to casing. I found using google images can give you a good idea and scooterhelp website and modern Vespa forum were also usefull. When I get home from work I can post some pics of my porting work if it helps
Posted: Wed Oct 22, 2014 9:09 am
by GLscoot
Rich
Don't know if you can see the link but this has been posted on modern forum, very good thread.
http://modernvespa.com/forum/topic128784
Gary
Posted: Wed Oct 22, 2014 9:45 pm
by wack 63
Get yourself some metal putty to plug the casing transfers that are not used.
Posted: Wed Oct 22, 2014 10:16 pm
by fairspares
it all depends on how far you want to go but heres a link to start with, http://www.scooterhelp.com/tuning/vespa ... rting.html
there are ways of opening the inlet and transferes right up but you will be stuck with reed valve and cant go back to rotary.
Posted: Fri Oct 24, 2014 6:32 pm
by sean brady scooters
fairspares wrote:it all depends on how far you want to go but heres a link to start with, http://www.scooterhelp.com/tuning/vespa ... rting.html
not true ,there are ways and means of reedvalving vespas that allow a return to rotary induction .basically the pad is left intact but the crank modified more :)
Posted: Fri Oct 24, 2014 7:32 pm
by fairspares
yes Sean , but as i said it all depends how far you want to go , if you do both and open the cases up to the max for a very high horse power motor then really there will be no return to rotary , what we need to know is what the engine is going to be used for?
Posted: Mon Oct 27, 2014 4:41 am
by Richjak
Thanks for all the invaluable information guys very much appreciated.
As to the point of what I want to achieve from the engine then the answer would have to be "fast road use" I know that in itself is a bit of a cliché in the world of scooter tuning but what I mean is I hope to make my engine run efficiently for the equipment that I have chosen to use. I.e. what would be the point of the Malossi 210 kit if you didn't match the transfers in the casing ??
What would be the point of utilizing a reed valve if you didn't match the intake on the casing.
I know that is a bit vague but I am sure you all get the jist of what I mean. I am not after trying to get every single ounce of power out of the engine to the degree that it goes bang every five minutes.
I think that the porting shown on the Scooter help page is more what I am after, after all this stuff costs a fortune so I will start with a more basic porting set up and then go from there once my skills knowledge and confidence have grown.
Once again thanks for all the pointers and information.
Posted: Wed Oct 29, 2014 12:47 am
by santacama
It is all about the exhaust you are going to use.
Posted: Sat Nov 22, 2014 7:45 am
by Richjak
Quick update:
Piston skirt has been cut off to allow for the 60mm Crank and the piston transfers ported as per a German website I found - (http://www.worb5.com/malossi_210_211_dr ... alossi.htm) Then after matching the gasket faces to the cylinder and then transferring them to the engine casings, and then removing the excess material things are starting to move ahead.
I do have photos I wanted to post but for some reason I cant post them.
I have the crank but I am still waiting for the 23/64 primary drives, the packing plate and the MMW cylinder head - once I take delivery of these Items I can start the rebuild and get the casings closed up.
