Page 1 of 3
Fitting Vespa Forks?
Posted: Wed Oct 15, 2014 8:50 pm
by eadmr04
Re: Fitting Vespa Forks?
Posted: Wed Oct 15, 2014 10:04 pm
by wack 63
They should go right to the bottom. You may need to emery the forks to get the dust shield down but the bearing track should be a tight fit and will need a tubular drift to knock it down. Don't force it if very tight as it will pick up the alloy or even split.
Posted: Wed Oct 15, 2014 10:20 pm
by GLscoot
wack 63 wrote:They should go right to the bottom. You may need to emery the forks to get the dust shield down but the bearing track should be a tight fit and will need a tubular drift to knock it down. Don't force it if very tight as it will pick up the alloy or even split.
Agree.
It looks as if there is paint on the section. remove the paint and everything should be ok, the steering stop and the section of fork is made from alloy so no need to worry about rust. Film of grease should help get the dust cover all the way down.
I use a small wire brush on a drill, to remove the paint.
Gary
Posted: Wed Oct 15, 2014 10:30 pm
by eadmr04
Thanks guys, will try removing the paint and see if I can get them on without to much pressure. Any suggestions on something suitable to use as a drift?
Posted: Wed Oct 15, 2014 11:36 pm
by GLscoot
When you have removed the paint you shouldn't need anything, if you use grease it should slide on no problem. If you feel it is still not sitting properly, try using standard plastic plumbing tubing and putting the dust cover in the freezer for a couple of hours. The area should be clear of any paint dust ect and make sure there are no nicks, scratches on the forks that may damage or foul the cover. Its also easier turning the frame upside down, making sure you have enough clearance at the other end for the forks to drop into the frame, the weight of the forks should do the rest. You must also apply loads of grease to the bearing race.
Gary
Posted: Thu Oct 16, 2014 2:41 pm
by eadmr04
Cheers Gary
Posted: Thu Oct 16, 2014 3:23 pm
by sean brady scooters
HEATING UP the bearing race and the dust cover will expand them and make fitting even easier
freezing things makes them smaller/tighter .
Posted: Thu Oct 16, 2014 10:56 pm
by eadmr04
Got the bearings and forks fitted all ok now, thanks. They're forks for 10" wheel (gl, sprint) sort and I'm putting then in a VBB/Sportique frame. Anything in particular I need to look out for? I'm going to have to drill new holes in the flat plate on the forks to line up with the mudguard holes on the side but anything else that might need doing?
Posted: Fri Oct 17, 2014 10:26 am
by GLscoot
sean brady scooters wrote:HEATING UP the bearing race and the dust cover will expand them and make fitting even easier
Yeah. Freezing contracts and heat expands. What was I thinking, sorry.
What engine are you fitting.
Gary
Posted: Fri Oct 17, 2014 2:01 pm
by eadmr04
I've managed to squeeze a 200 engine in by fitting a non autolube carb box and lid (slightly less tall). Just about misses the frame when on the stand now after a bit of gentle "tweaking" and clears fine when sat on it off the stand.
Just wondered if there was any difference in length of forks/mudguard positioning, e.g. a big gap between the mudguard and horncasting, anything like that? I've had to make my own recess at the top of the forks as the machined recess for the headset pinch bolt was 90 degress out, but that's all sorted now. I r5ealise I will have to drill 2 new holes in the mudguard mounting plate as they are in a different position but just wondered if there might be anything else I might come across?
