Removing VNB front mudgaurd?
Posted: Fri Oct 10, 2014 12:17 pm
by djh66
I've removed the forks from frame, and all the bolts associated with the mudguard, and I realise you have to get it at the right angle to remove it, however, the dust cover for the bearings is stopping it being removed! Any ideas?
Re: Removing VNB front mudgaurd?
Posted: Fri Oct 10, 2014 12:25 pm
by CPH Lambretta
Remove the lower bearing and dust cover, then it will come off a treat.
Posted: Fri Oct 10, 2014 1:05 pm
by djh66
CPH Lambretta wrote:Remove the lower bearing and dust cover, then it will come off a treat.
Thanks CPH, I applied a bit of heat and the race and cover came off lovely.
