Page 1 of 2
Converting PX Autolube Engine to Pre-mix?...Advice needed
Posted: Thu Oct 09, 2014 6:30 pm
by cartmel808
I've just bought a brand new, complete PX210 Malossi engine (ebay bargin) & I'm going to stick in me Rally 200 - but it's an autolube engine with oil pump & I just want to run it on pre-mix - so what's the best solution for disabling the autolube?
Do I just seal the end of the oil feed pipe.... Or do need to remove the oil pump altogether & plug the inlet hole with something?
Cheers...
Re: Converting PX Autolube Engine to Pre-mix?...Advice neede
Posted: Thu Oct 09, 2014 7:01 pm
by Speed Demon
Take the carb and carb box off, pull the shaft out and replace the box and carb with new gaskets.
Without the dive shaft you won't wear the dry-running pump mechanism out. The gaskets will be enough to make sure the gear oil can't escape but you could also silicone the shaft hole up too if you are paranoid.
Posted: Thu Oct 09, 2014 7:04 pm
by cartmel808
Great....thanks!
Posted: Thu Oct 09, 2014 7:40 pm
by sean brady scooters
i always plug up the oil injection hole in the carb with a lead shot to block it off ...belt and braces approach especially if the pump is left in situ .
Posted: Thu Oct 09, 2014 8:27 pm
by bazman
Take clutch out and remove small toothed cog that turns the oil shaft
Posted: Thu Oct 09, 2014 9:05 pm
by Speed Demon
bazman wrote:Take clutch out and remove small toothed cog that turns the oil shaft
And then the clutch sits 3mm closer to the crank, and directly against the main bearing Baz!
Posted: Thu Oct 09, 2014 9:25 pm
by GLscoot
Speed Demon wrote:bazman wrote:Take clutch out and remove small toothed cog that turns the oil shaft
I think he means the small cog held on by the small cir clip to the left of the clutch. I use one of these
http://www.ebay.co.uk/itm/350441849345? ... EBIDX%3AIT
Posted: Thu Oct 09, 2014 10:36 pm
by Speed Demon
Oh, yes, sorry Baz
Posted: Fri Oct 10, 2014 6:45 am
by bazman
Yes GL scoot that's the cog I was on about !!
Posted: Sat Oct 11, 2014 10:11 pm
by dirtyhandslopez
Try putting a non-injected gasket between carb and box, no need to worry about oil passage way in carb.
