spanish turning mudguard
gerryjunior
Xbox live gamer tag: no
Playstation gamer tag: no
Main scooter: lambretta li 2
i want to fit a turning mudguard to a series 2, do i need to change anything in the steering bearings ,, thanks.
elb1
Main scooter: eibar s2 li150
It requires a bit of welding. I have some pics of the work required which were given to me by gaz Powell if your interested? I was going to do it but managed to pick an s2 eibar up 8-)
gerryjunior
if you mean the welding of brackets on the forks, i understand that , just not sure about the steering cups , dust cover etc, im building a rallymaster replica over the winter, thanks.
elb1
That's what I meant I've got pics and dimensions for the cup work and additional mudgaurd brackets
gerryjunior
thanks id appreciate it if you'd post the pics.
gaz_powell
this is a set of Italian S2 that I converted to take a f/g turning mudguard and dampers
all you need to do is knock off the dust plate then turn the ring and weld it on
I can email the rim dimensions if you pm your email
Gaz
PS cant take credit for it - I got the info from kind persons off LCGB
elb1
Nice one gaz :lol:
gerryjunior
thanks for that , ill pm you, nothing else needs doing, frame end ?
gaz_powell
nothing else to do
details are on my pc at work so I`ll send them
gaz
Yanker
gerryjunior wrote:thanks for that , ill pm you, nothing else needs doing, frame end ?
Correct horncast?
