PM Tuning Crank
Posted: Thu Oct 09, 2014 10:00 am
by stokky
Hi all,
ages ago I ended up with a PM Tuning Lambretta crank (Not sure but think at time, dealer I used only had this crank in).
Anyways, fitted a week or so ago to a Rapido 225.
Seemed really, really stiff, so stripped down to check.
Checked all standard stuff. kickstart catching on clutch etc.
Had another crank handy so swapped, and all OK.
In my view the seals on each side of the crank are too tight a fit, and stop the crank turning freely.
Incidentally fitted AF racecrank, using same seals ect and no problems.
WIll measure up tonight.
So question, is this just me or anyone else seen this ??
Maybe thats why don't see many PM cranks about
Re: PM Tuning Crank
Posted: Fri Oct 10, 2014 9:30 pm
by Yanker
Well you wouldn't do in all honesty would you if you think about it. Unless you have XRay Specs or have been foraging through bins? http://scooterotica.org/forum/viewtopic ... crank+fail
I was saving for one, but will get a BGM or re-build on my 'Tino' crank (miles done).
Have you micked the seal seating surfaces and compared? Some seal manufacturers have various spring tension grades, usually a further digit after the seal size in the range 1>6 tightest?
