Thoughts , jetting/exhaust
Posted: Sat Oct 04, 2014 9:55 pm
RT195 , 30mm Delorto AS266 ,X7 3rd clip , 50 pilot , 125 main , 40 slide. Static timing at 17.
Started running in with a PM pipe and all was fine when keeping the revs low and being gentle.
Got to about 250 miles and wanted to start opening it out and wasn't sure about the jetting so had a quick dyno run came out with 17bhp but topped out at 54mph. Results showed a little lean low down and slightly rich at the top end. Tried it on the road and flat out 52mph and wouldn't accelerate hard. Felt like it did when it was way too rich.
Spoke to the guy who dyno'd it and he said the exhaust could cause similar problems.
Next took the PM off and put a Clubman on, 64mph but won't rev much over 6,500 revs.
Richend up the lower end and it struggled so this is where I am now.
It runs well enough , rides nicely if you accelerate gently but still holds back if you try and give it everything..... which I tend to do.
I will bee trying to borrow an expansion chamber exhaust to see what happens then. I did wonder if the PM was blocked , it shouldn't be carbon'd up as there is probably less than a couple of thousand miles on it.
Any ideas ? Should it rev higher ? A mate has a similar set up that is good for 70 , where mine seems to struggle up to 64.
