mallosi 166 ign setting
Posted: Tue Sep 30, 2014 6:04 pm
by shocky
Ok not that up on vespa px ign timing currently set to the IT mark on stator but theres another mark inthe clock wise direction were should I set the mark ?
Re: mallosi 166 ign setting
Posted: Tue Sep 30, 2014 6:59 pm
by sean brady scooters
leave it on the IT mark matey ,thats 18 degrees BTDC .
Posted: Tue Sep 30, 2014 10:20 pm
by shocky
sean brady scooters wrote:leave it on the IT mark matey ,thats 18 degrees BTDC .
Many thanks
Posted: Tue Sep 30, 2014 10:22 pm
by lambro
Would you trust it Sean, or strobe it just to check??
Posted: Wed Oct 01, 2014 8:42 pm
by gaz_powell
If its a genuine piaggio flywheel and stator plate it will be fine without strobing.
I`ve never strobed a vespa and set loads up - never had an issue with timing - caveat to that they have all been genuine piaggio parts
Posted: Wed Oct 01, 2014 10:05 pm
by lambro
gaz_powell wrote:If its a genuine piaggio flywheel and stator plate it will be fine without strobing.
So the Swiss stator and Piaggio flywheel on mine will need a strobe then :lol:
I was going to for peace of mind, as I have had numerous bad experiences with Indian electrics :|
Posted: Thu Oct 02, 2014 4:58 pm
by gaz_powell
I would strobe it then just in case !!
My experience of a SWISS stator is not good - needed a stator in an emergency and the only one availble was a SWISS - I put it on and used the timing marks at IT same as the gen piaggio one I was running. The bike was a bag of sh"+e - wouldn't accelarate or rev clean, missing , speed down and me rev counter was going dolally. Took it off and replaced with a piaggio one that I rebuilt and all good ! Rattled to IOW and back without skipping a beat and rev counter working fine.
Hopefully it was a one off and you'll be okay.
Posted: Thu Oct 02, 2014 10:32 pm
by lambro
gaz_powell wrote:I would strobe it then just in case !!
Hopefully,
But not likely :lol:
Posted: Tue Nov 04, 2014 9:09 pm
by lambro
Thought I would update this re: the Swiss stator.
Fitted and strobed and was a little out, adjusted and got it spot on with a timing light.
That was at low revs, as soon as the revs were raised, the marks moved and it was firing almost TDC :shock:
Changed CDI and still the same, swapped it for a Piaggio stator and my marks now stay still at all revs.
Odd :?
Posted: Tue Nov 04, 2014 10:48 pm
by gaz_powell
I`m glad you posted that update
it does point towards SWISS stators !
Gaz
