MB wiring loom.
Posted: Mon Sep 29, 2014 1:02 pm
by 10 inch Terror
Has anyone fitted the latest simplified MB wiring loom lately? I'm useless with wiring and was wondering if anyone has a diagram they could post. Ive got Sticky's book but the loom pictured in it seems different to the one I have. I managed to fit one of theirs 4 years ago and it was fine. This one is much different though. Any help would be most appreciated. Thanks in advance Pete.
Re: MB wiring loom.
Posted: Tue Sep 30, 2014 2:11 pm
by Jxmiddle
This would be a good question to get an answer to......
Re: MB wiring loom.
Posted: Tue Sep 30, 2014 2:33 pm
by jason frost
Starting from the back, pink (brake) and black (light) to the back light, then green to your coil, red and yellow ( should be connected together for AC ) to the voltage regulator, red next not used on AC, red and pink to the brake switch, red with a ring terminal not used on AC, red to horn, pink for a front brake switch, red not used on AC, yellow power to brown on switch, black to black on switch, green to green on switch. I think
Re: MB wiring loom.
Posted: Tue Sep 30, 2014 3:17 pm
by cartmel808
Red 2 Red... Black 2 Black.... Blew 2 Bits!!
Or that's how it normally works when I'm attempting to wire something....
Re: MB wiring loom.
Posted: Tue Sep 30, 2014 3:47 pm
by 10 inch Terror
jason frost wrote:Starting from the back, pink (brake) and black (light) to the back light, then green to your coil, red and yellow ( should be connected together for AC ) to the voltage regulator, red next not used on AC, red and pink to the brake switch, red with a ring terminal not used on AC, red to horn, pink for a front brake switch, red not used on AC, yellow power to brown on switch, black to black on switch, green to green on switch. I think
Thanks Jason.
