Rapido 225
Posted: Sun Sep 28, 2014 8:06 pm
by Livi- Graeme
My mate has a rapido fitted.can you get different size base gaskets and head gaskets to get the squish set correctly. Currently it's over 1.5mm cause it won't even dent the solder I use.will I get them from af Cheers Graeme
Re: Rapido 225
Posted: Sun Sep 28, 2014 8:19 pm
by Muppet
yes
Re: Rapido 225
Posted: Sun Sep 28, 2014 8:33 pm
by wack 63
Build it with no gaskets first to get a squish measurement
Re: Rapido 225
Posted: Sun Sep 28, 2014 8:40 pm
by Livi- Graeme
Thanks. Am I right in saying this kit didn't come with a head. Could it be possible that the head that's fitted does not suit the kit. Not stripped it yet.cheers Graeme
Re: Rapido 225
Posted: Sun Sep 28, 2014 9:49 pm
by rosscla
Is it definitely a 70mm head?mWhere is the piston in relation to the top of the barrel at TDC?
Agree with wacks tho' build without gaskets first and measure, then it's arithmetic.
Re: Rapido 225
Posted: Sun Sep 28, 2014 11:48 pm
by corrado
The kits don't come with a head but AF have a 9.5 comp skimmed one or a low comp 8.5 one.
Re: Rapido 225
Posted: Mon Sep 29, 2014 9:51 am
by a.lo.v2
i first built mine as it came with a gasket this was about 13 years ago and it ran fine. when it came to rebuild later and with more knowledge about things like squish i tried to measure it but could not get a reading so left out gasket and came out at about 1.3-1.5 iirc so seal it with bathroom silicone and has never let me down. i have always belived these kits would suit a longer stroke as the piston does not fully clear the exhaust at bdc either. after all these years i do have a 60x110 bgm but it came available too late for the last rebuild with the cyclone so ill have to wait a bit longer.
Re: Rapido 225
Posted: Mon Sep 29, 2014 5:11 pm
by Livi- Graeme
All sorted. Took out the 1mm head gasket and fitted a 0.5mm to give a squish of 1.5mm exactly. By the way the head was already an af. Happy days thanks for everyone's input. Graeme
Re: Rapido 225
Posted: Mon Sep 29, 2014 9:06 pm
by Trojan
Happy days, just make sure that you take a few measurements as I did the same thing with the head gasket, then lapped the head on a piece of glass to make sure it was level, a quick way was to mark the gasket face with a marker pen, this will show any high areas when lapped, and don t forget to seal the head when fitting..........hope this helps.....
Re: Rapido 225
Posted: Mon Sep 29, 2014 10:02 pm
by Livi- Graeme
Done an air test on it and everything's all good.
