Dodgy steering bearings.
Posted: Sun Sep 28, 2014 6:29 pm
by 10 inch Terror
Hi all, has anyone come across upper steering bearings that are too small to fit the cone and race? I've just tried fitting a set and they are too small. I've tried them in 3 races and 2 new cones and they are too small in all of them. It's not a major deal I know but it's frustrating as they are supposed to be 'top quality' and I've had to order another set which has now slowed my rebuild up.
Re: Dodgy steering bearings.
Posted: Sun Sep 28, 2014 6:44 pm
by fairspares
thats how the top bearings come now, fit them and then tightened gently, undo and you will see they fit in the top bearing ring.
Posted: Sun Sep 28, 2014 6:57 pm
by 10 inch Terror
fairspares wrote:thats how the top bearings come now, fit them and then tightened gently, undo and you will see they fit in the top bearing ring.
I tried that and the forks were very stiff. I'm now going to split both bearings and fit them 'loose' hopefully that'll sort it. Thanks for your reply.
Posted: Mon Sep 29, 2014 8:12 am
by Jxmiddle
I fitted the bearing loose and the difference in feel is significant. Bit of a pain to do but worth the effort imho.
Posted: Mon Sep 29, 2014 11:00 am
by Minority
The other benifit of fitting loose bearings is that you can fit more ball bearings in if you want to. This distributes the load better and the bearings should last longer.
Posted: Mon Sep 29, 2014 12:54 pm
by 10 inch Terror
I fitted loose bearings to my other Lammy and to be fair it was a pain to do. This is the reason I was just going to fit them as they are on this build. Looks like I'll have to bite the bullet and fit them loose again.
