old li150 short barrel
Posted: Sat Sep 27, 2014 2:39 pm
by elb1
Hi, I've just picked up an old li150 barrel and head.(with cast hump in the inlet. Three fins below exhaust port type).
I was thinking of using it to practice and learn a bit more on tuning. Is there any draw backs on these short barrels apart from bit less cooling. Also what's the max it can be bored.
Re: old li150 short barrel
Posted: Sat Sep 27, 2014 5:22 pm
by Ian Hepworth
The ports are tiny so need a lot of work.
You can do an easy 190 with a TS185 piston but the piston skirt may need shortening.
Posted: Sat Sep 27, 2014 7:24 pm
by elb1
Thanks ian. Think I'll give it go After a bit more research
Posted: Sun Sep 28, 2014 9:33 am
by kevspeed
Used one many moons ago with a Kawasaki KH 400 piston,and if memory serves,the only real modification was taking 1mm off the top of the barrel!
Posted: Sun Sep 28, 2014 11:39 pm
by Grumpy225
elb1 wrote:Hi, I've just picked up an old li150 barrel and head.(with cast hump in the inlet. Three fins below exhaust port type).
You'll find the cast iron in those jugs is a lot harder than the newer cylinders (old US tank steel I think). Plus like Ian said, the ports are tiny. This means a lot of grinding just to get to normal port sizes. If it's a true 150 jug then you should be able to bore out to 64mm. Best to measure everything before sourcing parts.
For playing around I'd just get a cheap Indian 150 jug and learn off that.
Posted: Mon Sep 29, 2014 12:56 am
by elb1
Cheer lads, I'll keep it as a spare standard replacement if its hardly worth the effort. I didnt realize it was the old barrel when I hit the buy button. I'm starting get a pile of stuff that will never get used :lol:
Posted: Mon Sep 29, 2014 5:28 pm
by Grumpy225
elb1 wrote:Cheer lads, I'll keep it as a spare standard replacement if its hardly worth the effort. I didnt realize it was the old barrel when I hit the buy button. I'm starting get a pile of stuff that will never get used :lol:
Need some more? I think I have the 125 version of that cylinder.
Posted: Mon Sep 29, 2014 5:42 pm
by elb1
I think the postage will cost more than my scooters worth grumpy :lol:
