Page 1 of 2
EGT probe position on JL3 - thoughts?
Posted: Wed Sep 24, 2014 8:02 pm
by alanscottj
Hi guys,
Can anyone please advise on where the probe for a EGT gauge goes on my exhaust (JL3) - where is the recommended position for me to weld the nut?
Many thanks in advance!
Re: EGT probe position on JL3 - thoughts?
Posted: Wed Sep 24, 2014 8:06 pm
by Muttley McLadd
Doesn't it tell you in the clues?
I'm pretty sure mine is 4" from the piston.
Posted: Wed Sep 24, 2014 8:27 pm
by alanscottj
Muttley McLadd wrote:Doesn't it tell you in the clues?
It doesn't, it has a picture of where it should go, I think the picture is off a car exhaust, the distance is not clear. You mention 4" from the piston, I have heard this before. Have you welded yours on?
Posted: Wed Sep 24, 2014 8:36 pm
by Muttley McLadd
Yup. I'll take a pic when I get to work.
Posted: Wed Sep 24, 2014 8:38 pm
by alanscottj
Muttley McLadd wrote:Yup. I'll take a pic when I get to work.
Your a gent, cheers
Posted: Wed Sep 24, 2014 9:45 pm
by Muttley McLadd
Pics a bit big - sorry. I'm at work, and it's an inept PC.
It's a bit minging. Not had a wash since.. about April.
Posted: Wed Sep 24, 2014 10:10 pm
by alanscottj
What exhaust is that on?
Posted: Wed Sep 24, 2014 10:14 pm
by Muttley McLadd
JL RHS.
The metal bit to screw into is generic though. That came with the gauge.
Posted: Wed Sep 24, 2014 10:19 pm
by alanscottj
Muttley McLadd wrote:JL RHS.
I am going to have a go with 4" from the piston, I am hoping to get the scoot to the dyno in October. Hopefully the dyno operator will be able to advise on safe running temperatures for me. What sort of temps does your run at?
Posted: Wed Sep 24, 2014 10:33 pm
by coaster
alanscottj wrote:Muttley McLadd wrote:JL RHS.
4" from the piston skirt is correct and the tip needs to be inserted into the middle of the exhaust stream. Mine's fitted to a JL3 and I positioned it to the rear of the pipe reasoning that it would be a bit protected from flying stones.
What make of probe is that MM?
colin
