How to reduce vibration.....
Posted: Thu Sep 11, 2014 2:03 pm
by Jxmiddle
I'm looking for all the possible ways of reducing vibration on my Lammie. I'm sure there's loads of things you can do which would all together make a huge difference. Comment people? Thanks.
Re: How to reduce vibration.....
Posted: Thu Sep 11, 2014 2:09 pm
by dapper
Not overly tightened engine bar nuts. Larger silent blocks. Handle bar end weights. Foam handle bar grips. Just a few to start with.
Posted: Thu Sep 11, 2014 5:35 pm
by shocky
Make sure your flywheel and crank are balenced and true
Posted: Thu Sep 11, 2014 5:37 pm
by dave411
What are handlebar weights?
Posted: Thu Sep 11, 2014 6:02 pm
by monument7
Couple of carrier bags filled with shopping ????
Posted: Thu Sep 11, 2014 6:15 pm
by dapper
dave411 wrote:What are handlebar weights?
They're bits that you stick in the ends of the handlebars which are said to reduce vibes, man. Think Power Ranger bikes have them.
Posted: Thu Sep 11, 2014 7:47 pm
by bryansmudge
MB sell brass throttle and gear change wheels for inside the head set, increasing the weight at the head set with these and handle bar weights will reduce the vibration, something to do with increasing the mass of the handle bars vrs the vibration transfered from the engine/ road. The bar end weight work cos I've got a pair that I drilled out slightly deeper and infilled with some fishing weights and araldite.
Don't know how much the stuff from MB costs tho
Posted: Fri Sep 12, 2014 10:15 pm
by Muppet
dont start the engine
Posted: Sat Sep 13, 2014 2:44 pm
by sean brady scooters
check that the inlet manifold/cylinder cowl /exhaust all clear the frame.
