AF road clutch
Posted: Sun Sep 07, 2014 12:01 pm
by chippy
Do you set clutch lever with a lot more play than a standard clutch
Re: AF road clutch
Posted: Sun Sep 07, 2014 7:39 pm
by 10 inch Terror
chippy wrote:Do you set clutch lever with a lot more play than a standard clutch
Mine has the normal amount of slack at the lever. To get the best from the AF clutch make sure you fit the best inner and outer clutch cable you can find. I have an MB one and its got a lovely light action and the biting point is spot on.
