avanti carb settings
Posted: Thu Sep 04, 2014 9:35 pm
by steve chapman
just built an avanti for a mate and he is using a mikuni tmx35 with a franspeed race pipe
has anyone elese got this set up . if so what jets ect are you using , thanks Steve
Re: avanti carb settings
Posted: Thu Sep 04, 2014 10:07 pm
by Andy Pickering
Might be best to give Ron a buzz Steve, can't be sure but someone might have posted one a while back, most are on dellys
Posted: Fri Sep 05, 2014 7:22 am
by stew
Currently running mine on 20 pilot, 57 needle (2nd clip) and 310 main on a JL3. Still running it in however been fine for 500 miles so far and I have rung it's neck a few times.
Posted: Fri Sep 05, 2014 7:54 pm
by steve chapman
thanks guys , my mate spoke to Ron and hes not sure but thinks
when he had a mikuni it was 57 needle 2nd clip 300 main and 22,5 pilot
does that sound about right , Steve
Posted: Fri Sep 12, 2014 6:17 pm
by mick1
stew wrote:Currently running mine on 20 pilot, 57 needle (2nd clip) and 310 main on a JL3. Still running it in however been fine for 500 miles so far and I have rung it's neck a few times.
Hi Stew.
Looking at putting a Mikuni on my Avanti as well....what was the rest of your set up (gearing, timing, etc).
Thanks
Mick
Posted: Fri Sep 12, 2014 8:52 pm
by stew
Hi Stew.
Thanks
Mick
Mick I have static timing at 17 degrees, Li box 46 x 17. I am in NZ though, conditions very similar to uk in regard of there is no humidity here yet.
If you haven't run the kit yet you will not be dissapointed.
Posted: Fri Sep 12, 2014 10:29 pm
by mick1
stew wrote:
Hi Stew.
Thanks
Mick
I have been on the road with the Avanti for 3 years now (kit no. 71). I've been running a Dellorto 30mm PHBH but i have a bit of boggines in the low revs. I'm hoping the Mikuni may perform a bit better than the Dellorto. I'm still very pleased with the performance and if the Mikuni performs that will only be a bonus.
Posted: Sun Sep 21, 2014 1:26 pm
by paul190
I been using the mikuni tmx 35 on My Avanti kit and it has been working very well.
set up is
57 needle 2nd clip
17.5 pilot
290 man jet .
Also run a remote filter now as I used to run open mouth and got tired of cleaning up the mess after a ride .
Still it runs like a top.
Mind you this is with one of Ron's big bore club man pipes .
