Problems adjusting a Vespa Rally200 clutch
Posted: Wed Sep 03, 2014 12:58 pm
Took a fairly new and fully working clutch assembly out of my P200 engine and put it into a Rally200 engine, including the spacer before I put the clutch on.
However, when I came to adjust the clutch, I had to keep pushing the clutch arm against the springs of the clutch, to a point where the nipple was set around a further 30mm up the cable from the initial compression point.
I’m now at the position where the clutch is still grabbing in first gear. But if I use the fine adjuster, a few turns out, I’ve gone too far and the kickstart does not engage.
Any clues as to what I may have cocked up, as I’m still a Vespa virgin
