Page 1 of 2
blue bearing
Posted: Fri Aug 29, 2014 9:53 pm
by hendy
In order to fit the inner race of the mag side bearing to my crank I heated it with a heat gun.
After I fitted it (with consumate ease), I noticed that I had "blued" it with the heat.
My question is; is my inner race f@@ked?
I hope not as I can't be arsed to replace it, especially on a brand new crank in case I damage the crank in the process. Equally I don't want to build a brand new engine with a bearing that will fail after 1000 miles.
Re: blue bearing
Posted: Fri Aug 29, 2014 10:39 pm
by Yanker
I think that the 'blueing' is not good news because: that is a visual sign that it has over heated. Either it will be warped or the hardening of the surface will be compromised. An adult will....etc
Re: blue bearing
Posted: Sat Aug 30, 2014 5:05 am
by Grumpy225
You cooked the race, sorry.
Why did you heat it at all? They usually knock right on with the right tool (which is cheaper than a new bearing).
Re: blue bearing
Posted: Sat Aug 30, 2014 6:50 am
by hendy
Bugger. In my heart I knew it was dead, but I was hoping there would be enough people telling me not to be stupid and they all did that.
Anyone got just an unused inner race for sale? Skf only........thought not. Wallet open again.
Re: blue bearing
Posted: Sat Aug 30, 2014 6:52 am
by hendy
Grumpy225 wrote:You cooked the race, sorry.
Just followed sticky's advice: if you don't have the correct tool etc........
Re: blue bearing
Posted: Sat Aug 30, 2014 7:14 am
by wurzel
Sounds like it's buggered marra,inner race should drift on pretty easily and shouldn't need heating
Re: blue bearing
Posted: Sat Aug 30, 2014 7:51 am
by dave411
If you really need to do something other than drift it on,try freezing the crank
Re: blue bearing
Posted: Sat Aug 30, 2014 8:37 am
by rosscla
Freeze the crank, put race in boiling water and they often drop on
Re: blue bearing
Posted: Sat Aug 30, 2014 11:20 pm
by joey
..all may appear well now..after a few thousand miles the track will have spun loose on the crank and knackered it....
Re: blue bearing
Posted: Sun Aug 31, 2014 6:11 am
by warts
If you use the freezer method, a dash of water displacer/oil on the big end bearing will prevent condensation and then rust forming and also knackering the job.
