NOS TS1
Muppet wrote:does the scomadi use stock type dampers?
Do you mean the scooter or scamadi forks ? the scooter uses an outboard shock with a 12mm fixing pin top and bottom like this but these are of my own making ;)
gpts1
Had a bit of time to get some more machining done, so it is now almost ready to fit into the forks and have a look how I'm going to set up the anti dive on it .
gpts1
Hi All, was pretty busy around the house over the Christmas new years break but managed to get the disk into the fork to see what it looks like.
guygrrr
Main scooter: 1980 Vespa P187
Very trick! It's nice to see it coming along.
more can do, less doodoo.
rudeboy67
Main scooter: lambretta series 1 ,SX200
Lovin the work in this keep it up cant wait to see final result !
gpts1
Got my TS1 back for my Buddy Kevin, hes an awesome engine builder and drag races his GP down here in New Zealand, his best time so far is 13.4 @98 mph
Next job on the list is to get the cylinder shroud modified to fit my center plug head.
gpts1
have managed to get a little done, but not as much as i would like,
Cylinder shroud was done, then i discovered fan was to far away from the fan cover, so Ive modified that to close up the gap and will be getting the shroud modified to suit.
stripped and detailed my PWK, plus modified it to fit my nitrous injector
Forks were stripped again and new stainless brackets welded in the right place this time
Also added the anti dive bracket as well.
Discovered a small crack in one of the lower fork half's obviously from when they were formed, so that was fixed also.
Forks are just about ready to put back together now after Ive finished remetal finishing them.
gpts1
forks are back together, and i done a bit more machining work on the disk brake
gpts1
Got all the body panels in primer over the weekend
gpts1
few photos to update you where im up to.
