Page 1 of 2
Fork links
Posted: Sun Aug 10, 2014 8:09 pm
by Cmoono
just got my first lambretta, after a string of vespas, is there anyway of putting the links in with out the tool and whilst the forks are in? cheers
Re: Fork links
Posted: Sun Aug 10, 2014 8:25 pm
by corrado
You can get GP ones in without the compressor [just about] because of the loose balls on the spring rod but with fixed ball type of the SX/Li is near impossible and that's with the forks out. Dropping the forks is the easy part.
Re: Fork links
Posted: Mon Aug 11, 2014 11:31 pm
by Norrie Bodge
Sorry to hijack on this thread?
Regarding GP buffers, im just in proceess of doin mine, & where the bottom buffer clips in on one side this has come away..
is this essential to keep the buffer in place??
Cheers
Re: Fork links
Posted: Tue Aug 12, 2014 12:00 am
by paulmgreen
Yes "
Re: Fork links
Posted: Tue Aug 12, 2014 3:10 am
by Norrie Bodge
paulmgreen wrote:Yes "
Cheers on the reply...
Can this be fixed??
Re: Fork links
Posted: Tue Aug 12, 2014 6:38 am
by shocky
You can get new buffer clips but they need welding in or you can fit theearler type of buffer that are fitted in with bolts butyou needto drill the forks for this
Re: Fork links
Posted: Tue Aug 12, 2014 7:01 am
by paulmgreen
What Shocky says !
Re: Fork links
Posted: Tue Aug 12, 2014 7:03 am
by Norrie Bodge
shocky wrote:You can get new buffer clips but they need welding in or you can fit theearler type of buffer that are fitted in with bolts butyou needto drill the forks for this
cheers m8
U know who does them??
Re: Fork links
Posted: Tue Aug 12, 2014 7:53 am
by shocky
What the drilling if so its something you can do your self the buffers are the LI/SX type
Re: Fork links
Posted: Tue Aug 12, 2014 12:17 pm
by Norrie Bodge
id rather keep as std
does anywhere does the GP type & ill weld them in m8
cheers
