Rear brake failure. Oil ingress
Posted: Sat Aug 09, 2014 11:42 pm
by Bufficus
I've been having trouble with my otherwise perfect working back brake due to oil ingress from the gear box. I've replaced the final drive oil seal 3 times (Rolf seals seated properly) which lasts a few miles until the oil comes through onto the shoes. The bearing is Casa Lambretta with no play. The problem started after I broke my Cyclone 5 speed for the first time. The casing was thoroughly cleaned but the bearing was never replaced. I guess the shrapnel has lunched the bearing/layshaft combo and this is the problem. Everything feels right and tight but I presume the filings have damaged the bearing.
I don't even know why I'm asking I've got to change them.
Re: Rear brake failure. Oil ingress
Posted: Sun Aug 10, 2014 1:27 am
by Donnie
Assuming it's not damaged the lay shaft itself
hope it's just the bearing though.
Posted: Sun Aug 10, 2014 7:37 am
by coaster
If there is no play in the bearing I would think the area of the lay shaft were the seal contacts is damaged.
Posted: Sun Aug 10, 2014 9:22 am
by Muppet
chek y layshaft o'ring
Posted: Sun Aug 10, 2014 10:19 am
by Minority
Muppet wrote:chek y layshaft o'ring
MB agrees with you
Posted: Sun Aug 10, 2014 10:43 am
by paulmgreen
Replace o ring !
Posted: Mon Aug 11, 2014 8:58 pm
by Bufficus
Thanks for the replies fellas.
I'll start with the 'O' ring and go through the process of elimination.
Posted: Mon Aug 11, 2014 10:12 pm
by paulmgreen
Make sure you thoroughly clean the hub and casing with brake cleaner ... New pads too?
Posted: Mon Aug 11, 2014 10:38 pm
by Toddy
Check the bearings not spinning in the casing I've had that before
